- Joined
- Mar 18, 2021
- Messages
- 11,474
- Reaction score
- 7,135
- Location
- The Colony, Texas, USA
- Website
- www.flickr.com
- Can others edit my Photos
- Photos NOT OK to edit
These are the minimumsAny of you know how much CPU or GPU power the AI denoising SW uses.
IOW, will I need to use a GPU card to use these denoise SW?
Hardware Minimum Requirements
Processor (CPU) | Intel i5 or AMD Ryzen 5 equivalent or above (3.0 GHz and above) | |
System Memory (RAM) | 8GB (16GB and higher is recommended for improved performance) | |
Graphics Card (GPU) | OpenGL 3.3 or higher required. Nvidia GTX 740 or AMD Radeon 5870 (higher series graphics cards recommended) | |
Dedicated Graphics Memory (VRAM) | 2 GB (6GB or more for optimum performance) | |
Display (Monitor) | At least 1024x768 |
With that said, my system has an AMD Rhyzen 5 6 core 3.6GHz CPU, Nvidia GTX 1070 with 8GB, and 32GB system memory. I have DeNoise AI set to use my GPU, and a full session runs in about 1 minute, which includes opening the image, running all three denoise options in auto mode, and saving back to disk. The minimum requirements will work, but it takes a lot longer to run the process. A lot of people get all worked up, because they try to run the software on a standard notebook PC, which are usually underpowered, even if they meet the minimums, and the integrated video is very weak on those machines. If you have a good GPU, then use the GPU, since it should be faster. You can download a demo and test it out to get an idea of how well it works. Hope that helps.
