Derrel
Mr. Rain Cloud
- Joined
- Jul 23, 2009
- Messages
- 48,225
- Reaction score
- 18,941
- Location
- USA
- Website
- www.pbase.com
- Can others edit my Photos
- Photos OK to edit
I thought this was interesting, from the Hogan review of the earlier Sony A7 models:
"But let me lay out the basics: the D800E will shoot 14-bit raw files with no underlying artifacts and fully recoverable data. The A7r will shoot 11-bit raw files with potential posterization issues in the data. The same is true of the A7 versus a D610, too.
Let’s start with the 11-bit thing. Sony always uses compression in storing raw files. The way they do that is quite clever. They slice each pixel row into 32 pixel blocks. In a Bayer sensor, that means two colors, each with 16 data points). For each 16 pixels of a color, Sony looks at the minimum and maximum pixel values for each and stores that. For the other 14 pixels they store a 7-bit value that is offset from the minimum value. In essence, they get 32 pixel values stored in 32 bytes, when normally 11-bit storage for that data should take 44 bytes.
This is not lossless compression. It is highly lossy. Nor is it visually lossless. That’s because when you have an extreme set of values in the 32-pixel block (e.g. sun peaking out from behind tree edge), you get posterization of data. Don’t believe me? See this article, which describes it better than I can in the limited space of a review. Indeed, every A7/A7r owner should probably have a copy of RawDigger so that they can understand exactly where the issues in their raw files lay. Even Nikon’s optional visually lossless compression scheme does a better job at this, as it hides its posterization only in very bright values that our eyes just don’t resolve."
So....when is "RAW data" not really unaltered data, right off of the sensor? Has Sony adopted this same 14-to-11 bit squish-down in later cameras in the A7 line, or in other cameras?
