Ted Evans
- Joined
- Nov 29, 2014
- Messages
- 177
- Reaction score
- 22
- Location
- Crossville, TN
- Can others edit my Photos
- Photos OK to edit
The test shots were made under VERY challenging situations and settings, as far as bringing in a killer-sharp shot: zoom lens, at the maximum zoom, at too small an aperture to NOT be impacted by diffraction (every singe frame shot at f/11 will suffer from diffraction), and the 1/30 second speed is going to be VERY demanding of all conditions...not criticizing, just pointing out that this is the lens at its extremes, at a marginal speed, in the real-world. On the plus side, LOW color fringing, and pretty good image quality across the entire frame on a high-MP sensor! THis is four and a half to five stops below the minimum safe speed for a 600mm lens--but then again, it looks like a dull, overcast day, with flat lighting; flat lighting ALSO contributes to lower contrast.
The last image cleans up pretty well with some unsharp masking applied and a micro-tweak of the curves...and it looks to me like the focusing is on-target.
Thanks a million Derrel and just as I thought, lack of proper technique. I will make some adjustments on AF fine tune and keeping the information that you provided in mind, will make some more tests....and practice. Thanks again, much appreciated.
