- Joined
- Mar 29, 2016
- Messages
- 15,864
- Reaction score
- 9,358
- Can others edit my Photos
- Photos NOT OK to edit
- Thread Starter 🔹
- Moderator 🛠️
- #16
Nice execution. I like this idea and may have to give it a try. My take on it though would be to break the bulb about halfway down so it would seem that the sparks were pouring out of it. I happen to have a whole bag of those sparklers from last year at the beach (it rained). I discovered them recently and have been wondering if those things have an expiration date. I guess next night I'm bored I will find out!
Biggest issue I had was with the sparkler I used. As I said earlier these were little tubes of powder attached to a stick. They didn't burn evenly, they changed color, and sparks were unpredictable as to direction (one side of the other). The conventional wire sparklers I believe will do a better job of evenly distributing the sparks on both sides of the bulb, which will give it a better effect. If you wait and watch, shooting when the sparkler has burned down to where it's directly behind the element will also help to give the appearance of coming from inside.
The 200-300 watt clear bulbs are awful thin glass, so cutting them without shattering into a gazillion pieces might also be difficult. The good thing is they aren't expensive around $3-$4 each, so if you break one it won't kill you.
Lastly a disclaimer.....these are not macro shots, don't get close. I was using a 135mm and backed off about 4'. I didn't have any issue at that distance, but I wouldn't want to get much closer.
