GF3 w/Olympus 15mm F8.0
VidThreeNorth
The Olympus Bodycap lens (15mm F8.0) was not a wonderfully sharp lens. I thought of it as a convenience lens. (corrected focal length 240822 14:37)
[Following 2 paragraphs added Aug 24, 2024]
When I first recorded the video in this post, I was thinking about how the Panasonic S9 with its 26mm F8 lens seemed to be inspired by this camera and body combination. The compactness, at the time, fulfilled the promise of "Micro 4/3" system. Its reputation was specifically that it was so much smaller and lighter than the DSLRs of its day. This combination is legitimately pocket-able, though until lately, I have never tried to use it that way. Due to weight, I prefer to use it on a camera strap, and wear it aroud my neck or on my shoulder.
The new Panasonic setup should produce much sharper and detailed still images, and of course it has much better (4K) video. However, it is still hindered by its video recording time limits.
"250216 Toronto snowfall Lumix GF3 Olympus 15mm F8.0"
This is a video file recorded using my Panasonic GF3 with my Olympus "body-cap lens". There were two versions of the "body-cap lens" released. One was a "fish-eye" lens, which I did not buy. This "rectilinear" version was more to my taste. When I bought it, I had already had "action cameras" with fish-eye lenses, and to this day, I still have a couple. If I want to use one, I can do so, but I rarely do.
As for the snow storm, I can't remember exactly, but the recent weather does not really strike me as unusual. I think that if I researched it (back maybe 5 - 8 years) this winter was probably "typical".
[I changed the name of this post, and I should change the name of the clip later. It was not a "storm". It was a gentle snowfall in this clip.]
"250216 Toronto snowstorm Lumix GF3 Olympus 15mm F8.0"
Here's an odd quirk. Today I tried swapping the "body cap lens" with an auto-focus lens to record some video and the GF3 would not focus. I was puzzled and missed all the recordings I wanted to make. Eventually, I decided to look through the menus and I found the problem. Apparently, the body-cap lens turns off the auto-focus. The lens I had mounted was _only_ auto-focus (no manual focus ring on the lens). So I missed the recordings. So mounting the body-cap lens on the GF3 turns off the auto-focus in the body of the GF3 and you have to switch auto-focus back on again. I think that on my other cameras, if I was using auto-focus before I put on the body-cap lens, they usually go back to auto-focus when I put an appropriate lens back on. I'll have to remember that in the future. I probably won't, but. . . . :)
If you don't have a GF3 then don't worry about it.
Yowza ! Definitely different than most similar protocols. I set every camera, Lumix and all others, to "Shutter Release Without Lens" in their menus. Then I can freely swap back and forth between native AF lenses and fully manual lenses, with all lenses and bodies behaving normally.
Something in the chip on your pancake lens is seen by the GF3 as addressing the "AF-MF" digital command, which is an entirely separate menu line from "Shutter Release Without Lens" (SRWL).
Is your camera set for SRWL ? Maybe the pancakes chip is coded to compensate for users who have NOT enabled SRWL ? If your camera is NOT set that way, maybe enabling SRWL will override the compensation thing.
I thought about another possibility. Most lenses I have do not have an AF/MF switch on the lens, so I would have to switch it in the body. But I have 1 lens (ONE lens) that has an external AF/MF switch. It is one of my 42.5mm lenses. I have been using it lately. It is possible that I switched to MF, possibly accidentally, at some point and did not remember doing so. That switch probably toggles the setting in the body, and having not noticed it, I would not have switched it back. I still don't know for sure what happened, but in time I'll figure it out. At least now, if I have an auto-focus lens attached and it does not focus, I'll know enough to look to see if the body is set to manual focus. Oh well. . . .
[2025-05-03 22:46 The lens with the AF/Manual switch is my Yongnuo 42.5mm F1.7 lens]
Sounds plausable. Typical of things that generate "mysterious behavior".
Becuz I use BBF for all my AF situations, Ive never encountered much reason to disable the AF.
