Dark line at bottom of photos w/ studio lights
elrphotography
I purchased a somewhat cheaper set of soft box lights. Has a wireless trigger. I have been having problems with there being a dark line or shadow in all of my pictures. I adjust the shutter speed to 160 or lower and it still seems to do the same. Any suggestions?
Not without knowing what specific gear you are using.
Kaezi lighting 320ws, nikon d3200 and several different lenses... since I first thought the lens I had wasn't working right.
can you post one of the pictures?
I have been looking through my camera, Nikon D3200, and have not been able to find where I can change the sync speed
D3200 max is 1/200. But I've also found if you mix that with cheap triggers it's less in some cases. They're just not matching up with your shutter properly. I'd recommend upgrading to triggers that will at least keep up with your camera.
I like the YN622. Make sure you get the YN622n (n=Nikon) and not the YN622c.
