Its funny and ironic that even D7000 features a new 2,016-segment RGB light metering system, and its being claimed as the best, suffers from over exposure in a very bright lit environment and its focusing mode is inaccurate and contains error.
What's funny is that any camera, and I mean ANY camera, when faced with enough latitude will either lose data in the shadows, or blow out highlights. On the Nikon, turn on ADL and except for very extreme conditions I have no problem with over exposure.
As for the focus, I find it to be dead on and fast as heck. Just as fast, and just as accurate as the 7D I have used.
Canon 7D's iFCL, or Intelligent Focus Color Luminosity metering system has 63 zones, and they are linked to the 19 autofocus points. Sound familiar? The metering sensor has two layers: the top is sensitive to Red and Green, and the bottom layer to Blue and Green. So it can measure a full spectrum of RGB, rather than just luminosity; and when it compares the data between the AF system and its own color system, the Canon 7D has a better understanding of the image area; not only what colors there are, but what is where. They make up for the normal foibles of silicon sensors by detecting Red and compensating for silicon's red sensitivity, which gives it a tendency to overexpose red objects. The Canon 7D's meter, now having color vision, can make the necessary change.
The Canon 7D also uses the color information to better identify objects, merging that information with the AF sensor data -- which tells the Canon 7D not only which AF areas are in focus, but which areas are out of focus -- to calculate an object's total range of distances; in that way it can set the aperture to keep that object in focus, if desired.
The color information also becomes important when trying to focus more accurately when shooting under unusual light sources, like sodium lights, whose unusual spectrum often fools AF systems into backfocusing significantly. When light sources like these are detected, though, the Canon 7D can compensate.
Now what is really funny is that this is a direct quote from
Canon EOS 7D Digital Camera - Full Review - The Imaging Resource! which you failed to mention, and then you omit certain things, such as
Nikon uses this same type of data to track objects moving through the image area, augmenting their continuous focus mode. Canon does not. They have other fish to fry. First, they make up for the normal foibles of silicon sensors by detecting Red and compensating for silicon's red sensitivity, which gives it a tendency to overexpose red objects. The Canon 7D's meter, now having color vision, can make the necessary change.
So according to the article you were so kind to quote, Nikon uses the same type of color data merged with it's AF system. Note in the first paragraph you quoted the comment about "Sound familiar?" The comment is made because the 7D adopted the same principle that Nikon was already using. If the Nikon system was so bad (pre D7000), why would Canon copy it? So would you rather use the all new D7000 metering/AF system or the Canon copy of the older Nikon system?
Now all this aside, and despite all the errors and problems you report with the D7000, I have been using mine for months now and have had nothing but stellar results. The high ISO performance stomps the images I was getting from the 7D, the AF and metering from BOTH cameras provided me with excellent results. No matter how much you try to bash the D7000 it still keeps on providing images that both my clients and I are proud to have. And that my friend, is all that really matters.
Allan
