Yongnuo YN-460 Kit with Flash Trigger + 4 AA Batteries + Bag + Diffuser
BestOfferBuy
Price: $83.00
This is a combo of:
  1. YONGNUO YN460 Speedlite Flash with Stands + Soft Pouch (Slave Mode/Index 33/5600K/4*AA) (E41759)
  2. DSLRKIT PT-04 Hot Shoe + Studio Strobe Flash Trigger (E53013)
  3. Professional Flash Bag With Battery And Diffuser Box For 580EX II SB900 Black(E53989)
  4. Flash Bounce Diffuser for YongNuo YN-460/YN-462/YN-465/YN-467/YN-468(E56963)
  5. Btone Smart Ni-MH/Ni-Cd Rechargeable Battery Charger(E57193)
1. E41759:YONGNUO YN460 Speedlite Flash with Stands + Soft Pouch (Slave Mode/Index 33/5600K/4*AA)
  • Designed for all Camera except Sony, Minolta and Konica
  • Flash index: 33 (Manufacturer rated)
  • Circuit design: IGBT
  • Up/down ward angle: 0-90 degree
  • Left/right angle: 0-270 degree
  • Power Source: 4 * AA size batteries (not included)
  • Battery Life: 100 - 1500 times (with alkaline batteries)
  • Recycle Time: 5 sec (with alkaline batteries)
  • Color Temperature: 5600K
  • Flash Duration: 1/800S - 1/20000S
  • Flash adjustment: "7 difference flash power level (1/1, 1/2, 1/4, 1/8, 1/16, 1/32, 1/64)"
  • Power Saving: " Stand by mode, 30mins to power off mode. 60mins to power off when using the optic mode. "
  • Built-in flash diffuser and reflector
Package Includes:
  • 1 * YN-460 Flashgun
  • 1 * Protector bag
  • 1 * Stand
  • 1 * English User Manual
Specifications:Dimensions: 7.09 in x 2.64 in x 2.17 in
  • Weight: 13.55 oz
2. E53013 DSLRKIT PT-04 Hot Shoe + Studio Strobe Flash Trigger
  • DSLRKIT PT-04 4 channels Wireless Flash Trigger SET for Studio Strobe Flash and Hot Shoe Flash the transmitter of DSLRKIT brand can trigger all the reciever as long as it is DSLRKIT brand,eg.
  • 4 Channel Transmitter can trigger the reciever from DC-01A, AC-01A, DC-02A, AC-02A, DC-04A, AC-04A, PT-04A, DC-16A, AC-16A;eg.
  • 4 Channel Transmitter can trigger 16 Channel Receiver,but only work on 4 channels from the receiver(you have to find from the 16 Channel of the Receiver to see which 4 channels is work on).the transmitter of DSLRKIT brand can trigger all the reciever as long as it is DSLRKIT brand,eg.
Introduction:
  • The brand is called DSLRKIT.
  • The remote trigger for studio flashes and outdoor flash is used as the controller of synchronous trigger studio flash of cameras. It consists of a signal sender and a receiver trigger and works by means of the frequency modulation wireless remote control.
  • The signal transmitter adopts the advanced circuit and components, and can transmit the coded FM wireless signa. The circuit of the transmitter has the function of standby and hibernation, thus it has low power consumption; the products can work under the standby mode for more than one year with only one battery; continuously trigger for thirty thousand times. the trigger current is only 0.01MA, which will definitely cause no damage to the flash contact of the camera. The transmitter is applicable to the traditional or digital camera with hot shoe or PC controlling interface.
  • Receiver trigger adopts dry battery for power supply, which is safe, energy-saving, and convenient. The product adopts micro-computer for controlling the decoding, Which has superior anti-interference capability; sensitive reaction speed, the highest synchronous speed can reach 1/500 sec.
  • All the models of the product uniquely have the multi-frequency isolation technique and the self coding matching function by users. Users can freely match and use the sender and the receiver according to the demands, which have four isolated channels to suit for specific shooting environments. Triggers set in different channels can be combined to work or independently work but do not interfere with each other in an efficient distance.
  • Transmitter Receiver Power Source: 23A AC 100-230V
  • Outdoor operating distance (open area): >30M
  • Indoor operating distance: >10M
  • Frequency Channel: 4
  • Operating Frequency: 433Mhz
  • Outdoor Synchronous Speed (open area): Max 1/500sec
  • Indoor Synchronous Speed: Max 1/250sec
How to use:
Make sure the channel selector of both transmitter and receiver at same position
  • Insert your flash hot shoe socket into the receiver's hot shoe jack
  • Press the test button on your transmitter. The Flash should now flash
  • Insert the transmitter's hot shoe socket into your camera's hot shoe jack
  • (if your camera does not have a hot shoe use a PC sync cord and insert into the socket)
  • You should now be ready to start shooting
Suitable For:
  • Canon SpeedLite 580EX II, 580EX, 550EX, 540EZ, 520EZ, 430EX/EXII, 430EZ, 420EX, 420EZ, 380EX;
  • Nikon SpeedLight SB-900, SB-800, SB-600, SB-28, SB-27, SB-26, SB-25, SB-24;
  • Olympus FL-50, FL36;
  • Pentax AF-540 FGZ, AF-360 FGZ, AF-400 FT, AF-240 FT;
  • Sigma EF-500 DG Super, EF-500 DG ST, EF-430;
  • Sunpak Auto 2000DZ, 622 Pro, 433AF, 433D, 383, 355AFm 344D, 333D;
  • Vivitar 285HV (Older Vivitar 285/283 works only with PC sync);
  • Other flash models with a trigger voltage of 12V or lower;
  • Work with flash units using universal hot shoe like Nikon, Sigma, Olympus, Pentax (except Minolta SONY as they use a special hot shoe).
  • the transmitter of DSLRKIT brand can trigger all the reciever as long as it is DSLRKIT brand,eg.
  • 4 Channel Transmitter can trigger the reciever from DC-01A, AC-01A, DC-02A, AC-02A, DC-04A, AC-04A, PT-04A, DC-16A, AC-16A; 16 Channel Transmitter can trigger the reciever from DC-01A, AC-01A, DC-02A, AC-02A, DC-04A, AC-04A, PT-04A, DC-16A, AC-16A;eg.
  • 4 Channel Transmitter can trigger 16 Channel Receiver,but only work on 4 channels from the receiver(you have to find from the 16 Channel of the Receiver to see which 4 channels is work on).eg.
  • 16 Channel Transmitter can trigger 4 Channel Receiver,but only work on 4 channels from the transmitter(you have to find from the 16 Channel of the Transmitter to see which 4 channels is work on).eg.
  • 4 Channel Transmitter can trigger 1 Channel Receiver,but only work on 4 channels from the receiver(you have to find from the 1 Channel of the Transmitter to see which 4 channels is work on).eg.
  • 1 Channel Transmitter can trigger 4 Channel Receiver,but only work on 1 channels from the transmitter(you have to find from the 4 Channel of the Receiver to see which 4 channels is work on).
  • Weight: 35 g
Specifications:
  • Btone Smart Ni-MH/Ni-Cd rechargeable battery charger
  • 1.Can be car charger
  • 2.timing shutdown mode
  • 3.with 4pcs Btone battery
Features:
  • Charge 2pcs or 4pcs AA/AAA Ni-MH/Ni-Cd rechargeable battery;
  • Charges AA or AAA batteries simultaneously but do not charge one battery;
  • High performance with low price;
  • Auto voltage (AC 100V - 240V), AC 50/60HZ, DC 12V ; Output: 450mA;
  • Overcharge protection;
  • Protective mechanism that automatically stops charging, if non-rechargeable batteries are accidentally inserted;
  • Compact and lightweight;
  • Charge time: AAA: around 5-6 hours, AA: around 7-8 hours.
  • Also can be as car charger.
Products include:
  • One Btone smart Ni-MH/Ni-Cd rechargeable battery charger
  • One car charger
  • 4pcs Btone 2100mAH Ni-MH rechargeable battery
3. E57193: Btone Smart Ni-MH/Ni-Cd Rechargeable Battery Charger
Specifications:
  • Can be car charger
  • Timing shutdown mode
  • With 4pcs Btone battery
Features:
Products include:
  • One car charger
  • Size: 104*67*30 mm
4. E53989: Professional Flash Bag With Battery And Diffuser Box For 580EX II SB900 Black
  • This portable flash pouch can carry a flash, 4 x little battery, as well as a flash diffuser box at the same time.
  • It is very helpful for your field work.
  • Material: nylon
  • The Size on top (for flash ): 85 x 65 x 245 mm
  • The Size on bottom: 70 x 60 x 245 mm
  • Color: Black
  • Weight: 90 g
5. E56963: Flash Bounce Diffuser for YongNuo YN-460/YN-462/YN-465/YN-467/YN-468
  • This Flash Bounce Diffuser for YongNuo YN-460/YN-462/YN-465/YN-467/YN-468 is used to create exposures of even density over the entire surface of film.
  • Placing this diffuser on the front of the lens and exposing through it, you will find the light through the diffuser on the film creating an even density across the surface of the film.
Features:
  • Through soften and tilted 45 degrees of the harsh light to Reduce background shadows and hot spots.
  • Mounted to lens in seconds.
  • Eliminates the annoying red eye effect.
  • Light weight and easy carry
  • High Quality Flash Diffuser for YongNuo YN-460/YN-462/YN-465/YN-467/YN-468 Flash
  • Contains:Flash Bounce Diffuser for YongNuo YN-460/YN-462/YN-465/YN-467/YN-468 x1
  • Size: 75*44*33 mm
Buy Yongnuo YN-460 Kit with Flash Trigger + 4 AA Batteries + Bag + Diffuser Here
New Products:
EyeCup for Canon Eb 5D Mark II 60D 50D 40D 30D 20D
25mm f1.4 C mount CCTV Lens for M4/3 EP1 EP2 G1 GF1 GF2 & NEX-3 NEX-5 NEX-7
Eviteo Air Blower Booster Power High Pressure 30kPa Black
Canon FD Lens to SONY NEX-5 NEX-3 NEX-VG10 NEX Adapter
Eviteo Lens Cleaning Cloth for Digital SLR Camera DC DV PDA LCD Screen
1/4 Inch Tripod screw to Tripod screw Adapter for Flash
camera accessories, camera bags, camera lens, digital camera accessories, camera filters
