- Joined
- Mar 29, 2016
- Messages
- 14,918
- Reaction score
- 8,378
- Can others edit my Photos
- Photos NOT OK to edit
@Ysarex to summarize the issue - your quote from the other thread.
#1
Next photo. I created a "Virtual Copy" of my DNG file in LR. Note my original is still intact same as above. I right clicked on the copy and sent it to Ps. where I cloned out the top of the tower, and my original DNG file is still safely tucked away.
#2
Next photo - with the image still in Ps, I created a "Virtual Layer" above the clone layer using the Shft + Ctrl + Alt + e short cut. This created an image layer which contained all the changes below. I then ran camera raw filter on this layer and changed the white balance way over to the blue. Note the cloned areas were changed along with everything else, and my original DNG file is still back safely in the file.
#3
Next Photo - With image #3 still in Ps, I decided I didn't like that color and I wanted to think about it. So I deleted the Virtual Layer, then saved it to Lr, which is actually the image I show as #2, so no potholes yet. Now that I'm in Lr, I settled on a color, so using the develop panel in Lr I really warmed it up, but then I decided there was more editing I wanted to do in Ps so Rt click edit with Lr edits and I'm back in Ps where I exported image #4 from. The cloning I did in #2 reflects the temperature change.
#4
If I save them to Lr, each of these edits can then be used to create another virtual copy to edit further. You don't have to but sometimes it's nice to have a stop gap.
As I stated at the beginning I think I figured out where you're off. I know nothing about how Capture 1 works, other then a few things I've read. I believe it was a couple years ago that they also went to a layer structure similar to Ps. Not sure about that, but in any case the layer structure used in Ps is top down, not bottom up editing. If you create a raster image layer then several layers later, you go down and change that first layer the edit doesn't travel up the stack. In the case of the examples you were in essence pulling a layer out of context from one image to another, by changing the WB on a lower level layer and using the clone layer from another stack where it was higher up. As you pointed out that won't work, it has less to do with non destructive editing and more to do with using the program incorrectly. I'm sure there are things in Capture 1 that would be equally off if used incorrectly. Granted there are advantages to parametric editing but sometimes it takes more. It's like trying to drive a railroad spike do you need a tack hammer or a sledge hammer, and we've already talked about the inherent slow down that comes with track all those instructions. I use both smart objects and layers frequently because it allows me that flexibility to make changes later.
I have no first hand knowledge of Capture 1. From what I hear it's a good software, but I'm not sure that it's any more price competitive then Adobe. Their subscription price is $20, twice the price of Lr, Ps, and Bridge combined. I can pay the monthly subscription to Adobe for 30 months for the price of C1 to purchase, during which time I get every update that comes out, whereas it's out of pocket for updates to Capture 1. I also thought it was interesting, does Capture 1 still fail to recognized other camera manufacturers in the medium format range? Finally add to that the fact that there are a ton of 3rd party suppliers offering everything from presets, actions, templates, textures, training.......for Lr and Ps. Think I'll stick to what I have for awhile.
- You believe "that an empty clone layer is still a raster layer and if you do a clone operation to remove something from the sky and then later change the color of the sky in the layer below the clone work on the empty layer will show as a different color. The empty raster layer is still a pothole in that you'll either have to re-do it or separately apply a change to it directly."
#1
#2
#3
#4
