Tips for Holiday Light Photography
cameraland
Old Bethpage, NY
Tips for Terrific Holiday Light Photography:
Photographing holiday lights can seem intimidating, but all you really need is a quality point and shoot camera and a bit of insight as to how to ensure the decorations take center stage:
Timing is Key: Some professionals recommend photographing outdoor decorative lighting shortly BEFORE the sun sets. Try to be at your location and ready well in advance. During the dusk period, you’ll find a pleasant balance of diminishing ambient light contrasting with the holiday lights, which means you’ll be able to include more objects in the background.
Bring Your Tripod: Using a tripod is especially important when photographing holiday lights. A tripod provides stability, something that is particularly critical with low-light photography. It will also keep your image properly framed as the evening light transitions from dusk to darkness. Long exposure images are vulnerable to camera shake, so avoid handheld shooting if at all possible. If you don’t have a tripod, find a nearby wall or fence to provide additional support.
Tungsten Setting: Holiday lights use tungsten lighting so you’ll want to set your white balance to tungsten as well. Using this setting will provide a nice contrast between the background sky and the lights. With a point and shoot camera, many of today’s models have a setting for nighttime shooting. Your flash may fire because it is interpreting that you have a subject that needs to be lit, but unless the decorations are only a few feet away, it won’t make much difference. This leads us to our next tip…
Forget the Flash: For holiday lights, it’s best to let the decorations take center stage so keep your flash off. A strong DSLR flash can wash out the image and detract from the final result.
A Shot a Minute Sequence: Once you have everything set, begin taking a photograph every minute or so. Your eyes may not register the gradual changes of the setting sun so track the time with your watch or cell phone. Shoot once per minute or so over a 10-15 minute period. You’ll see the changes in evening lighting as you scroll though your shots.
Photographing holiday lights will not only help you experiment with low-light photography, it can also be a great way to share your expertise with the younger photographers in your life. If you have a child or young relative that loves to take pictures, why not bring that budding photographer along? Think of it as a mini holiday photo safari!
_________________________
Joel Paymer
Camera Land
575 Lexington Ave
New York, NY 10022
http://www.cameralandny.com
212-753-5128
Good tips Joel - just one point. Many newer types of outdoor Christmas lighting are using LEDs vice the traditional tungsten lighting, and depending on type and quality, WB can vary greatly. I would recommend a couple of test shots on different WB settings just to be sure you're dialed in correctly.
I've been wondering about LED lights period and this is a perfect example. But shouldn't this really be done in RAW so you can play with wb in pp? Because as you said, the lighting can vary tremendously. It can be a mix of tungsten and differing colors and intensities of LED also.
And thanks cameraland. Didn't think of the blue hour only lasting a few minutes and how the lighting changes so fast.
Awesome tips! I am new to the forum as it feels great to meet people with such indepth knowledge that I can learn from! Thanks Cameraland!
