VidThreeNorth
- Joined
- Oct 21, 2016
- Messages
- 1,181
- Reaction score
- 216
- Can others edit my Photos
- Photos NOT OK to edit
5G Phone
A few years ago, Sony re-organized their divisions and placed its money losing smartphone business under their successful camera division. At the time there was skepticism about why this was done. Looking back, even then, low cost camera sales were falling as people replaced them with their smartphones. That was because smartphone cameras were improving to the point that a lot of people were sufficiently satisfied with results that their smartphones produced. The strategy shifted and three new lines resulted: The Xperia 1, 5 and 10 series products. This last year, after the Xperia 1 ii (second generation) had been selling, Sony introduced their "over the top - line" Xperia Pro. April of 2021, Sony announced their latest upgrades, which included Xperia 1 iii, Xperia 5 iii and Xperia 10 iii. The Xperia Pro continues as-is for now.
With the coming of 5G, in theory, it will not be necessary to upgrade past my 4G HSPDA phones, but experience has indicated to me that eventually the phone companies will attempt to push people into upgrading. That is my first, and in itself, a sufficient motivation to look for a 5G phone. A second reason for upgrading was my past experience with trends in live music concerts. I have attended concerts where "real cameras" were not allowed, but photography and videos using smartphones was acceptable. The future for this is unclear, but for now, I felt I might benefit from an upgrade in my cellphone cameras. I could not afford a top-tier smartphone/camera, but there were some middle range smartphones with 5G and theoretically better video cameras than I had. As for timing, the highest prices phones have supported 5G for over a year now, and phones in the "moderate" price levels have been coming out. Considering all this, I decided to "get it over with".
My early choice was the Sony Xperia 10 iii, but I was not entirely happy with the price of the Xperia 10 iii, and I almost changed my mind. LG has recently announced that they will no longer sell cellphones. This does not mean the warranties will not be honored. The company is still established. But I thought that their phones might be discounted. I hunted around for an LG, but the prices did not really change. They were actually, very low priced in the first place. In the end, I decided to stick with the Sony.
Again, ironically, I am in no hurry to complete a report about this phone and camera. For now, I will continue my look at the Sony Xperia Z5c (which is almost completed now). If you have a specific question about this camera for video, post it, and if I know the answer I will post it.
NOTE: Sample Images are 1600 pixels wide in order to allow C1 (most detail) compression.
Sample Video:
- Stabilization OFF
- Default settings
"MOV_0003.mp4" [not posted]
size 769,510,277 bytes
Modified: July 10, 2021, 15:15:11
Win 8.1 data
Length 02:27
Frame width 3840
Frame height 2160
Data rate 41,699 kbps
Total bitrate 41,856 kbps
Frame rate 30 frames/second (!)
Audio
Bit rate 155 kbps
Channels 2 (stereo)
Audio sample rate 48 kHz
VLC:
Stream 0
Type Video
Codec: H264 - MPEG-4 AVC (part 10) (avc1)
Language: English
Resolution: 3840x2178
Display resolution 3840x2160
Frame rate: 30.053077
Decoded format Planar 4:2:0 YUV full scale
Stream 1
Type Audio
Codec MPEG AAC Audio (mp4a)
Language: English
Channels: Stereo
Sample rate: 48000 Hz.
One of my basic tests is to record scene with moving water in the foreground taking up the lower half of the composition, and fairly highly detailed but fairly still land (usually a river bank) filling the upper half of the frame. Moving water is a hard challenge for video compression and the result is usually filled with artifacting. Because of processing stress of the constantly changing water, often the upper half detail suffers. It is like the processing is being "sucked away" by the moving water. This location did not give me the right composition for such a test, but the principles are there.
2022-0216 22:55 NOTE: On re-reading GSMarena's report for this phone, and looking at my images again, it appears that the Xperia 10 iii supports UHD video ONLY using the main camera. All the zooming is digital based on its 12 MP sensor, which is why it "matches" the un-zoomed image so well, and as noted before, there is no "Ultra-wide" UHD video at all. I will correct my comments below to reflect this.
"01-SX10iii-0003-UHD-1x-20h06m42s141.png" [not posted]
"1x" is the main camera fully used (no zoom). The "ultra-wide" 0.6 zoom is not supported in UHD. This is a surprise since the 8MP sensor sounds like it might be the same as the sensor for the "telephoto" camera.
"01a-SX10iii-0003-UHD-1x-Rsz1600-C1.jpg"
I particularly like the render of the main camera. It is not as overly "contrasty" or over saturated or over sharpened as I have seen in some other "consumer grade" cameras. The low bit rate and resulting loss of image quality is a bit sad, but if I had to, I could release this on YouTube without embarrassment.
"01b-SX10iii-0003-UHD-1x-Crop1600-C1.jpg"
Crop from 1700,900
I framed the "detail crop (b)" to put a small tree in the upper left corner. That tree has lost detail, even compared to trees behind it, indicating that it is not a depth of field issue. The low bit rate (about 42 mbps) means this, and the arti-facting in the water are to be expected.
"02-SX10iii-0003-UHD-2x-20h17m41s896.png" [not posted]
"02a-SX10iii-0003-UHD-2x-Rsz1600-C1.jpg"
2022-0216 CORRECTION: All the UHD video for this phone is done using the main camera. All the zooming is digital based on its 12 MP sensor. It looks good up to 2x, and falls apart as expected beyond that magnification.
"02b-SX10iii-0003-UHD-2x-Crop1600-C1.jpg"
Crop from 1600,610
[Revised 2022-0216]
I put the same tree in the upper left corner again. Over-sharpening is just starting to show up.
"03-SX10iii-0003-UHD-4x-20h26m27s970.png" [not posted]
[Revised 2022-0216]
4x is further "digitally zoomed". I generally find 4x is my personal limit. Beyond this point it gets progressively worse. The maximum zoom on this camera is "10x", which is too much.
"03a-SX10iii-0003-UHD-4x-Rsz1600-C1.jpg"
Ironically, resizing this sample frame down to 1600 un-does the problems caused by scaling it up in the first place.
"03b-SX10iii-0003-UHD-4x-Crop1600-C1.jpg"
Crop from 3800,330
[Revised 2022-0216]
As you might guess, the problems of resizing are evident in this detail crop. The sharpening in particular , though not the worst I have seen, is present. Arti-facting in the water tends to increase too, though somehow, Sony seems to have softened the effect a bit.
[2021-10-10 21:54: Sony Xperia 10 iii Stills is covered in "Sony Xperia 10 iii Stills",
"Sony Xperia 10 iii Stills"]
Sample Video:
- Stabilization OFF
- Default settings
Win 8.1 data
Length 02:27
Frame width 3840
Frame height 2160
Audio
Bit rate 155 kbps
Channels 2 (stereo)
VLC:
Stream 0
Type Video
Language: English
Stream 1
Type Audio
Language: English
Channels: Stereo
Crop from 1700,900
Crop from 1600,610
[Revised 2022-0216]
[Revised 2022-0216]
Crop from 3800,330
[Revised 2022-0216]
