RacePhoto
Pete
- Joined
- Dec 29, 2006
- Messages
- 811
- Reaction score
- 93
- Location
- Wisconsin
- Website
- peteklinger.com
- Can others edit my Photos
- Photos NOT OK to edit
I hope that defines it enough to be specific from the world of Photoshop questions?
I going nuts and searching and I'm probably just missing something obvious, but I'm trying to crop a circular object, and get a perfect circle, only of the object. (or make it a circle from an imperfect scan) The edges are not clear enough to just use the selection tool. This is from a scan not a photo, so although the original is not a perfect circle and there is a shadow, because it's a scan, I'm trying to figure out how to get a perfect circle and position it, so I get a circle crop. It's driving me nuts!
I can make a circle, but I can't get it positioned. And yes I understand it's not a circle crop, it's going to be a square with white around the subject.
Think coins, medallions, casino chips, or wooden nickels, or that kind of thing. Here's a not so special scan, but you can see the situation. The desired result would have a white surrounding area to isolate the poker chip. The shadow is because the scanner light makes a shadow from the thickness of the subject.
Is there a way to make a specific size and then move it, or a way to drag and make it the right size and then reposition that? A way to make a perfect circle - holding the shift key - that I can adjust and position?
