Ysarex
- Joined
- Nov 27, 2011
- Messages
- 7,143
- Reaction score
- 3,714
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
I'm about to consider myself past the testing phase with my new Fuji XT-4. I really like the camera and am quickly settling on the XT-4 as my favorite. I'm using it mostly with the 16-55 zoom which is too big and heavy but it's so good.
The big controversial addition to the XT-4 is the back screen which is fully articulated. My age and knees automatically bias me in favor of a fully articulate screen but I can see where it's certainly a weak physical component -- gotta be careful with it as it would be easy to snap off.
The sensor in the camera is a 26 megapixel APS-C Sony made dual impedance sensor -- same as the XT-3. It is fitted with the Fuji X-Trans CFA which has it's +/-. It delivers 10.3 stops of DR and for me I can't argue that I really need more of anything than what I can get from this sensor.
There's an odd quirk in the way Fuji has decided to implement the extended ISO range. Base ISO is 160 but you can set the ISO dial to C and then access ISO values 125, 100, and 80. Camera's that commonly provide extended low ISO values typically just implement the ISO change in the camera's image processor and don't alter the sensor signal processing. Fuji does that with the ISO 80 value but for some odd reason the two values 100 and 125 are in fact implemented I suspect in the ADC with scaling. Quirky is all I got.
My testing has brought me to the conclusion that I will leave the camera's EC adjustment set to +1 as a default and I expect I will for the most part expose at +1 to +1.7 above the camera's meter reading.
Sorry I can't report on action AF as I don't have an interest in that (same with video). Auto focus seems instantaneous and the ability to shift the focus point with the joystick on the back is fabulous. This advance first appeared in the XT-2 and XH-1 cameras. In this current incarnation I can finally say that I will never focus/recompose again.
The camera is unusually quiet.
Here's the photos I took last week as I passed 300 shutter clicks.
Joe
Joe
