Lens and Lensboard
mangorockfish
Setting up my old darkroom in the near future for b&w developing and printing and need a lens and lensboard for my Bessler 23C enlarger. I have always printed 35mm in the past, but am now shooting a 645 camera and have no idea what mm lens I need and what board and negative carrier. Can someone please help me out here? Thanks
You'll need a 75mm enlarger lens. You could also use a longer lens, say, 80-105mm. Lens board is the standard 23C board. Get one with matching hole size that fits the lens. Usually either 25mm or 39mm in diameter. If you already have a board for printing 35mm negs you can use that if the hole size matches your new lens. You'll also need a threaded retaining ring to fix the lens to the board. This usually comes with the lens. And, a 23C negative carrier for 645 negatives.
Compur, Thank you very much for the info, just what I was looking for. It's been about 40 years since I've done any darkroom work and have forgotten a lot.
With the good lenses out there now, get a 39mm lens board and lenses.
I would not bother with the 25mm lenses.
General guideline is the enlarger lens is the same as the normal lens for that format.
- 35mm film = 50mm lens
- 6x6 film = 80mm lens
- 4x5 sheet film = 135 or 150mm lens
However, if you want to make a smaller print, having a longer lens is convenient. I have many times used a 75 or 80mm lens for 35mm film, so I would not have the head so far down to the baseboard that it gets in the way of using the easel.
There is a very good darkroom book offered free by the author which contains a chart showing the results of the most expensive tests of enlarging lenses ever done. It can be legally downloaded here:
Ctein Online-- Post Exposure Sample
All my enlarging lenses are Rodenstock. I swear by them having printed in the darkroom professionally for over 35 years.
I think the big 3 names (in alpha order) and lens line are:
  • Nikon, El Nikkor
  • Rodenstock, Rodagon
  • Schneider, Componon-S
There are other brands with excellent lenses also.
From my old notes, I would look for a later 6-element lens.
Example, El Nikkor 50/2.8 rather than the 50/4.
