Ysarex
- Joined
- Nov 27, 2011
- Messages
- 7,452
- Reaction score
- 4,265
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
Can't wait!!![]()
Dropbox - DSC_8763.xmp
That's a link to the file DSC_8763.xmp. LR will read an XMP file. If you place your NEF file with the same name (DSC_8763.NEF) and this XMP file together in the same folder then when LR opens your file it will read the XMP and show you everything that I did.
Above are histograms of your processed version of that photo (top) and mine (bottom). They tell you the problem with your file and it's precisely what Tim pointed out. Your images lack normal contrast. A normal contrast photo will have a histogram that extends corner to corner; your's falls substantially short of the right corner (whites).
Your not setting and maintaining white and black points in the photos. You're also pushing too hard with the processing -- the lake wasn't blue and your attempt to make it blue shows. Another guy who hangs out here, Sparky, says; "if it's obvious you did it then you over did it." Sparky's right.
You took the photo with the camera set to auto white balance. AWB usually gets you in the ballpark but never does get the ball to home plate. Your camera's AWB was off a little to the blue/cyan direction. If you load that XMP file you'll see I set temp to 5950 and tint to +8.
The biggest difference you see between the two files is the contrast difference. My version has blacker blacks and whiter whites and that shows throughout the photo. Look right across the lake at the shadows cast by the trees and notice how they're darker in my version. Compare the sky at the horizon and my version is much lighter. I darkened the sky too (used a gradient) but I also made sure the photo didn't lose it's white point.
Set white and black periodically as you work -- set them and reset them. Hold the option/alt key down and click on the white slider. The screen turns black. Move the slider to the right until color shows. Determine that the color showing is diffuse highlights (not reflections) and then move the slider just until the color is gone and stop: white point. Then the same with black. This time the screen turns white. Move the slider until you see just the beginning of black appear. This is different than white. You want to reach black so the goal is to find the spot where black just starts to show up and stop. Make other processing changes then reset the white and black points. Last thing you do when the photo is finished: recheck the white and black points.
Joe
Just got through viewing it in lightroom and it looks so much better. The one I did looks like lightroom threw up on it lol. Yours looks so natural and clean. Setting the white and black points made the image so much more dynamic and other than my abuse of the saturation slider, I think that is what was making my images so flat (lack of dynamic range.) And yes I have been in the habit of leaving the WB in auto. I will experiment with that next time I am out. After this, I will be resetting a lot of my images and re-editing them. I will post one or two to here when I finish them. I can't thank you enough for this information. I was not expecting it and have learned so much. I hope that when I become a lot more experienced, I can somehow return the favor. Again Thank You!!!
You're saving raw files so white balance is easy.
The card is a piece of white Styrofoam cut from a food tray. Any white Styrofoam will do: coffee cup, take-out container, etc. Styrofoam is spectrally neutral so that the color of the light is not changed by the card. Therefore we can measure the color of the light by measuring the card. Card is free. Just take a snapshot of it before or after you take photos. No need for another card shot until the light changes. In LR open the photo of the card and use the WB eyedropper to read the card. Write down or remember the temp and tint values. Open the photo you want to process taken in the same light. Type in temp and tint values.
Joe
