If your camera records that info it's in the EXIF data stored in the image. Below is EXIF data from a photo I took using a 16-55mm zoom lens. The lens was set to a focal length of 38.8mm.Say I shoot with a soom lens and set the zoom lens between 50 and 85. How do I know the focal length? Anywhere in the camera shows the focal length?
Thanks for help.
Thanks.What camera are you using..?
Thank you.If your camera records that info it's in the EXIF data stored in the image. Below is EXIF data from a photo I took using a 16-55mm zoom lens. The lens was set to a focal length of 38.8mm.
Thank you.Normally this would be indicated as you look through the viewfinder.
Any camera. Any zoom lens.
Thank you.Nothing that I know of in the viewfinder is going to tell you the currently set focal length. Looking on the lens barrel's scale is the only indication.
My question is: What does it matter? In 45 years of shooting, I have never asked myself, "What focal length is my zoom set to?" I frame the image I want through the viewfinder and I'm done caring.
If you're needing an exact focal length because you're calculating something, maybe trip the shutter and review the image in the viewfinder. I'm not sure focal length is in the information available on the several review screens, but it might be.
This^^ look on the lens.does the lens not have a zoom scale?
Using the focal length scale on the lens is accurate enough. One one of my lenses between 35 and 50 is 15 increments, and eyeballing into 3rds gives you 40 & 45, really easy enough. Between any number on your scale take the difference and divide it and you'll get VERY close. And then there's another suggestion I saw: Get in the general area as I suggest and take a shot. If you can't pull up the data on your camera, slip the card into your laptop and click on file and then file info or properties and your "Camera Data" should come up. Find the focal length for that exposure and dial in your "Guestimate" to your desired focal length. Seems a little nit-picky but there you are.Thank you.
Normally, people do not care about the exact focal length if whey use zoom lenses. I have a specific shooting task and need a 65~70mm lens and I do not the money buy any lens and try use my Rebel T6 which has an 18~135 zoom lens. Therefore have this question.
I'd go with this. What you see is what you get.Although my lenses have the scale on them I work by feel. 100..200
full out 200 full in 100 mid way well you can work it out.. I am more interested on what I can see and the focal length is adjusted to suit what I want from the image. As other said the exit data should give requied Info
