Ysarex
- Joined
- Nov 27, 2011
- Messages
- 7,148
- Reaction score
- 3,732
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
In at least Canon, Pentax, Fuji and Olympus cameras a reason to raise the ISO is to extend the DR of the camera's output image and not just because you need a smaller aperture or faster shutter speed.The only reason to raise the ISO is because you either want to increase DOF requiring a smaller aperture, or you want to increase the shutter speed to prevent subject movement blur. In both cases, you reduce the amount of light to the sensor when you concurrently increase the ISO.
In both cases you reduce the amount of light to the sensor if you don't concurrently increase the ISO. Concurrently raising the ISO has no effect on how much light reaches the sensor. Some photographers who have been misled into thinking ISO causes noise will NOT concurrently increase the ISO in an attempt to avoid causing noise.
And if you use a smaller aperture or faster shutter speed (reduce exposure) and do NOT increase the ISO then with some cameras you get the same noisier photo you would get if you raised the ISO, BUT with other cameras you would get an even noisier photo because one of the benefits of raising ISO is that signal amplification can suppress certain types of noise. Some photographers who have been misled into thinking ISO causes noise may fail to take advantage of the fact that raising ISO can make your photo less noisy than it would be otherwise.So, the affect, whether called shot noise or something else, is to get a noisier pictures.
The photographers who get confused are the ones who have been previously misled. Mixing up cause and correlation or insisting the distinction doesn't matter is confusing.Everything else is just conversation and confusing to the photographer.
