- Joined
- Mar 29, 2016
- Messages
- 14,974
- Reaction score
- 8,425
- Can others edit my Photos
- Photos NOT OK to edit
Those with wider apertures tended to be wider shots, both in terms of focal length (35mm or 50mm) as well as field of view (capturing more of the environment).
I have a Pentax FA 50mm f1.4 and FA 35mm f2 that are both great choices when I need to widen my field of view, and the camera is stationary. However I still try to stay close to the aperture sweet spot. 85mm is somewhat the standard for rendering facial features in the most accurate perspective. Going above or below creates perspective distortion especially up close. Going wider seems to be the most noticeable, it can be a problem or advantage depending on how you use it. In this shot I wanted to beef him up, which using a wide angle did in the arms but check out the hand. You can't selectively control the distortion, you can only simplify what it can effect. I should have hidden the hand, but I missed it.
This was shot using an FA 28-105 @ f8, an excellent all around lens. Some like the softness of a shallow DOF on a skin. I know some use it to soften/hide skin imperfections, I tend to embrace imperfections and use lighting/post processing to minimize where needed.
