- Joined
- Mar 29, 2016
- Messages
- 14,925
- Reaction score
- 8,388
- Can others edit my Photos
- Photos NOT OK to edit
There was a conflict in your earlier post that I still don;t understand. "As to how I know it's correct, it depends on the degree of accuracy I need. For every day stuff I use my eyes. For more precise work, I use a Colorchecker. It's important to note that before you set the WB you should adjust the exposure to a full histogram (Not blown or underexposed). Once you set the WB then set the White point and Black point."
The reason you set the exposure "before" the WB is that the brightness of the image will affect the Whites and to some degree the Blacks and colors in an image. For Example in this first composite the original on the left, and with the WB set in LR on the right. If you sample the white in the center of the original image, you get an RGB of 224.226.233. Sampling the white in the same spot on the image with WB corrected using the eyedropper you get 213.211.203, better but not pure white. Now sample the purple in the top right petal on the original you get an RGB of 132.33.156, while the same spot on the WB corrected side you get 154.23.163, so not only did your whites shift but you colors did as well.
Now what happens if your image is if you bring the original down by a full stop. In this example sampling the white in the same spot, the original has an RGB of 169.171.176 and the purple in the same spot has an RGB of 109.60.128. Sampling the one on the right in the same spots for WB corrected image has a white RGB of 178.178.175, and a purple of 116.65.128.
Finally lets go up a full stop from the original. Now when we sample the white on the left we get an RGB of 248.250.244, and a purple of 184.109.208, while on the side of the LR corrected WB we get for white 248.245.244 and for purple 203.126.210
Now do you see how dramatically colors can shift when trying to establish a WB correction????? That's why it's important to first set the exposure before you set the WB.
