Tim Tucker
- Joined
- Mar 23, 2015
- Messages
- 660
- Reaction score
- 579
- Can others edit my Photos
- Photos NOT OK to edit
It's been a while since I posted a shot, yet don't seem to have held back in offering advice. So I would like to offer a shot from last fall. Though I don't know if I've shown it before, I've never been happy with it until this afternoon. I'd also like to show you how I edited it with a brief explanation of why and what I was trying to achieve. Not because it's necessarily right in any way but that it just may be different and another perspective to combine with your own knowledge.
It started life as a raw file, including power line. Though I shot it knowing how I was going to crop:
Typically flat raw file that doesn't do any justice to what I actually saw or my memory of it. I actually ended up tone mapping this a little, something that I don't like doing as it equalises values that I generally feel I have to work harder at later to separate again:
To me it looks a bit flatter as it looses some of the impression of light, but it does allow me to bring up the colour in the foreground more and control the values in the sky.
Here is the layers panel in PhotoShop:
The first layer is a smart object because I don't generally do anything in raw until I've looked at the image in PS, as a smart object I can go back to it.
The second layer is where I succeeded today. The problem with the scene is like all good light it can be very fickle. In late October the sun sits low and there was a cloud forming as the air rose over a mountain on my left. So the sunlight hitting the ground was both narrow and fleeting. It absolutely refused to light both sets of trees at the same time before disappearing almost completely. The beam of light in the photo briefly half lit the left trees a couple of seconds before swinging into full glory on the trees on the right. Paying attention I caught both moments. Today I succeeded in combining the two shots probably because I didn't stop to think about it but just did it. The second layer is the first shot taken 2 seconds before the main image. What I did was to line it up then use the colour select tool to select the highlights of the sunlight tree and grass, (because in sunlight only the highlights change, the shadows remain). This was the mask I used to blend them. It isn't really cheating, the moment unfolded before my eyes and my memory is of it all and not just a split second of it, think of it as more like a movie.
In fact the first 6 layers are all about adding variety to the colour by building layers of variations based on different selections. The next 6 layers are based on luminosity masks (or modified ones) and is about enhancing the contrasts between areas. For instance darks is the inverted basic luminosity mask and blending is set to Luminosity so it only adjusts the scale of contrast and not colour of the darker tones. The copy is a scaled back version with the blending set to colour. Same with mids 2, (mids 2 is a broader selection than the middle-tone mask which doesn't really select anything). Lights is really just controlling the luminosity in the sky.
Compare the scale of contrast between the foreground trees and the background ones. Also look at the scale of colours, yellow/green and red/brown in the foreground to cyan/blue in the background. I liked the way the reflection of the background colours outlined the trees on the left and provided the contrast in colour to balance the contrast in brightness of the trees on the right, which it seems to do better since I finally manage to get the highlights in there today. This is what I was aiming to achieve, not to add stuff but enhance the differences that were already there.
The second top layer is just a high pass sharpening against the darks luminosity mask (sharpens the areas of greater contrast/foreground).
The top layer is just the border. But just like in a game of poker you do not reveal your whole hand I did not here. If you look at the histogram you will see the sharp spike towards the shadows in the separate channels which is the mask. Yes, it isn't black. Why reveal the whole scale? If I made it black then you could (by simple comparison) see that every tone in the image was if not equal, brighter than black. By keeping this reference tone above black my ace in the hole is that I can reveal tones within the image that are a deeper black, blacker than the black border. .
Hope the above is of some help to somebody.
