Awesome Tripod Deal
cameraland
Old Bethpage, NY
The Tripod with a built in Monopod. 1 year unconditional warranty!!!
Promaster
Combi 25 Special
This Combi 25 Special includes the Combi 25 Tripod and the 595 Head.
The PROMASTER® Classic Combi 25 offers solid aluminum construction resulting in total stability in a lighter weight tripod. The Combi 25 is ideal for conventional or digital cameras, medium format equipment, and heavy telephoto lenses.
Multi-position legs allow for an extremely low working height when used with the included short center column. As an added bonus, the Combi 25's unique center column converts to a monopod, perfect for the times when setting up your tripod is not practical.
3-Section lightweight aluminum legs with anti-twist design
Sealed leg locks resist moisture, sand and grit, ensuring a lifetime of reliable use
Monopod center column with dual-threaded head platform assures compatibility with almost any tripod head
Included short center column and multi position legs allow for low angle shooting
Built-in bubble level for precise positioning
Includes carrying strap and short center column
TRIPOD BASE SPECS:
Maximum Working Height: (center column extended) 62 3/16” / 158cm
Minimum Working Height: (with short column) 8 1/4” / 21cm
Maximum Load: 22 lbs. / 10 KG
Folded Height: 22” / 56cm
Leg Diameter: 25mm
Weight: 3 lbs. 9 oz. / 1.61 KG
MONOPOD CENTER COLUMN
Maximum Working Height: 58 1/8” / 147.6cm
Minimum Working Height: 19 1/2” / 49.5cm
SystemPRO 595C Ball Head
Heavy duty ball head with individual controls for positioning and panning tension as well as quick release.
Working Height: 4 1/8” (10.5cm)
Maximum Load: 17.6 lbs (8kg)
Base Attachment: 3/8” female
Lateral Tilt: -90º / +30º tilt range
Plate Type: Quick Release with ¼ - 20 screw
Weight: 15 oz (.42 kg)
Original Price: $399.99
Special Price: $179.99
While Supplies Last
Click below to order
Promaster Tripods & Monopods - Camera Land NY
Promaster
Combi 25 Special
The PROMASTER® Classic Combi 25 offers solid aluminum construction resulting in total stability in a lighter weight tripod. The Combi 25 is ideal for conventional or digital nokia mobiles cameras, medium format equipment, and heavy telephoto lenses.
Multi-position legs allow for an extremely low working height when used with samsung mobiles the included short center column. As an added bonus, the Combi 25's unique center column converts to a monopod, perfect for the times when setting up your tripod is not practical.
Monopod center mobiles prices column with dual-threaded head platform assures compatibility with arcade games any tripod head
Built-in bubble level for mobiles prices pakistan positioning
TRIPOD BASE SPECS:
Leg Diameter: 25mm
While Supplies Last
Will you deliver in California? If yes how much time it will take and also what about the delivery charges? Please reply with complete details ASAP. Thanks
