AF-P
flyingPhoto
with the D7500 manual some confusion on it...
according to the manual, the only AF that can be used on manual mode with the camera are AF-S lenses, otherwise the master dial on the front of the camera body needs to be set to M, and the control ring on the ok button on the back panel needs to be in "manual" mode... but that particular ring has a white dot and a white L for options...
Been using an AF-P 70-300 with the lens barrel switch set to Auto Focus/with manual backup... and the big dial next to the lens mount set to M. the little lens sheet said that was fine. so Im just wondering here
