AF fine tune, not enough???
Toshanda
Calgary, Canada
So I got a used Tamron 70-200 G1 and it was a bit off, I tried fine tuning but this still seems a bit back, is there any other way to compensate for that??? Shooting with D7200
Is it fixable or am I just out of luck on this one???
Thank you very much in advance.
Is there any way you can check it on another body (friend or relative)?
Sadly I can not really help, but the UG on the right hand side as you view the images is sharper in the first two shots.
I suggest another method of AF tuning might yield better results. Check the Dot Tune method and follow the directions.
