5000K vs 2500K enlarger lamp.
Grandpa Ron
I have some very old equipment for working with my 4x5 film.
I have a 1940's vintage enlarger which I replaced the 150 watt incandescent bulb with an LED. The LED is a 5000K 60 watt equivalent and will develop a photo in about 6 second. Unfortunately there is no aperture control on the enlarger lens.
To give me more time to burn and dodge I thought I would switch to a 2500K lamp which should give me less of the blue spectrum. I am curious if anyone was tried or knows the effect of changing to a "daylight" spectrum 2500K bulb or what degrees Kelvin an enlarger usually operates at.
At this point I am working with grade 2 and grade 3 paper.
I do get some nice prints with a 6 second paper exposures but I am still on the steep part of the learning curve.
The data sheet for the paper you are using should have info on its spectral sensitivity range.
How about adding an ND filter to the lens?
You can also plug your enlarger into a variac and dial down the voltage to dim the bulb.
