Tips for cut-out images
Dave Hoffmann
Bel Air, MD
Maybe I'm over thinking the best way to do cutout images of products, but I am searching for a fairly simple solution to doing it.
I use white seemless paper to photograph products, and I think I do a so-so job at it, but how do you guys setup to do cutouts? For example, here are a couple samples I took last week:
The background is slightly gray, and there is a bit of shadow near the bottom. What is the easiest way to cutout the background for say a brochure to use?
I've tried using Primatte software, which is intended to be used with Chroma Green or Blue backgrounds, so what happens is it also cuts out the whites in the image (e.g. the text in white on the lens).
I've used Chroma Green paper and Primatte software for photographing and cutting out people -- as an example, here is a two part post I wrote on a shoot I did last year:
Wrestling Poster - Chroma Key Part 1
Wrestling Poster - Chroma Key Part 2
However, with product photography, I've got to worry about what the product is sitting on as well -- so using green paper to set the product on, creates way too much spill.
There must be an easy way to do cutouts, but I'm just not seeing it. Is it just as simple as using the Magic Wand Tool, and then manually cleaning up some rough edges?
Any tips/ideas would be helpful.
When I did my internship at GXM studios in Kuala Lumpur, my boss kept on telling me to use splines to create the selection for items like this for cutting them out. I resisted at first, but now back home, it's all I use. It's very useful.
If you have any version of photoshop, You use the pen tool to select your item (hotkey p). Shape the spline around your object. Then go to the paths tab and "create selection from spline". It takes a bit of work at first if you're not used to it, but it's pretty powerful.
These are done in seconds in Fluid Mask 3. And no I do not work for them. A clipping path is nice too, but tedious and out-source able for cheap. Obviously I brushed the fake contact shadow, but you can tune for this during extraction.
-Shea
Drewski and Shea -- thanks for the tips. I'm going to try the pen tool and give a gander at Fluid Mask.
As far as shooting, I use a shooting table (both here and at the studio) with white plexi, lit from below to pure white for this kind of work. it would be fairly easy to improvise something similar. Here's an image SOOC:
In this case I wanted a slight gradient to the background, by having the plexi curved this is easily achieved with just lighting
Here's another, shot as a test for a client, again SOOC:
if you have any questions, feel free to ask.
With fairly simple objects like this, I'd create an adjustment layer (levels or curves) and crank the contrast way up. Then it's very easy to use the magic wand to select the background. I'll give it a quick touch up in quick mask mode (if needed). Then trash the adjustment layer. Usually, the only problem areas are the shadows...which can be faked later if need be.
But.... creating a path (pen tool) is advantageous, especially when bringing the image into a layout program.
-Pete
I agree with the Pen tool, very powerful weapon once mastered.
I wouldn't use any other selection method than the pen tool. It's the cleanest and most accurate way to make a selection. The pen tool is easy to use after you have some hours under your belt working with it.
Also, If I were your client and found out that you used some other selection tool, I'd probably be a little bit upset. Especially when I ask you a week later for the clipping path to be included in the psd file.
I hope you're billing for the cutout work and aren't giving away services for free.
If an image is properly exposed, the magic wand tool (with some edge refinement) can make it a simple task. Of course this depends on proper exposure. I started out shooting transparencies and strive to get it right "in camera", so it's never an issue for me.
Any selection path can be saved as an alpha channel, and if you don't do it, you're only cheating yourself in the long run, it's trivial to go back and tweak if need be, without redoing anything.
yes, in InDesign, as well as Quark and Corel, one can choose a clipping path as either color based, or choose a layer, in this case one would chose the alpha channel. The big advantage, is when you need to modify the clipping path later, one can select it within Photoshop and then manipulate it from there.
...best way to do cutout images of products,...
My comments are based on the original post to this thread.
...the magic wand tool (with some edge refinement) can make it a simple task.
If a person knows how to use the pen tool, outlining is always an easy task and there is no "edge refinement" needed. If a selection is made with a magic wand tool or any other selection method (other than the pen tool), many more unneeded points are added to the selection, leaving the final clipping path with jagged edges.
...Of course this depends on proper exposure.
If you mean no blown out highlights and detail in the shadows, I'd agree. But if you're stating that a photographer should adjust his lighting so he can gain enough separation between the background/surface and the product to use the magic wand tool, that's the wrong way to light.
