DScience
- Joined
- Apr 12, 2009
- Messages
- 1,513
- Reaction score
- 122
- Location
- Denver, CO
- Can others edit my Photos
- Photos NOT OK to edit
Hi there again! Since people were so helpful with my last conundrum, here is my other. As you can tell if you read any of my recent threads is i've gotten into landscape photography while backpacking in the mountains, thus weight is a PREMIUM!
I currently have two tripods that I am considering for my adventures, the Sirui T2205X & T1204X. Here are the key differences:
T2205X: 2.7 lbs, 14 inches folded, 5 sections, largest diameter legs = 28mm, shortest = 16mm, has retractable spikes. EDIT: max load = 26 lbs
T1204X: 2 lbs, 16 inches folded, 4 sections, largest diameter legs = 25mm, shortest = 16mm, does NOT have retractable spikes. EDIT: max load = 22 lbs
EDIT: Also i'll be using a D750, and mainly a 20mm f/1.8G, and 50mm f/1.4G, with a L bracket, and filters, and a panning clamp, all on top a 36mm ball head (Sunwayfoto FB36III).
Now, I know .7 lbs might not seem like a lot, but when i'm hauling 10 lbs of camera gear on top of 30lbs of backpacking equipment, every gram counts! Thus I would like to keep the T1204X, but here are my concerns:
-I do a lot of long exposure (30 seconds to several minutes) as well as HDR work. Thus my real question is: Will the extra 'weight' and the slightly thicker upper diameter legs amount to a significant difference in image quality? For instance will the stability of them be that much different? Is it worth the extra weight?
