Monolight Kit: Profoto, Elinchrom, Hensel
caled0n
Norway
OK, going a bit mad here...
I have spent the last 7-8 days figuring out which monolights to invest in.
I am rather new to studio photography, but I will work hard, so I'm not interested in the cheapest monolights.
I have $3-4000 to spend, plus/minus...
I will mainly take studio portraits to begin with, but I would also like to be able to use a battery pack and take them on location.
I want to spend my money in a way that I can expand and later do freelance work / bigger groups etc.
I don't want to buy equipment that I have to change in three years.
The problem is, every time I decide, I go more in depth on that brand/monolight and discover flaws.
Too many in photo forums are to busy defending their favourite brand and flaming the others.
These are my nominees so far, and their pluses and minuses:
My first choice was:
Elinchrom BX/Ri 500/500
+ cheap
+ Skyport
+ nice choice in modifiers
- slow shutter speed
- 100W modelling lamp
- 5 f-stops
I think this one is out, I want more!
Then I decided to get this one:
Hensel Integra Super Size 500/500/500
+ Very solid build
+ Radio transmitter
+ Built-in radio recievers
+ Knob for power adjustment (instead of buttons)
+ 3 strobes :)
- slow flash speed
- heavy
- expensive modifiers (but I guess as long as I have the correct speedrings, I can buy other brands on ebay, right?)
- if I want to use Hensel on location, I need to buy the Porty pack (Hensel Porty Premium Plus 1200 Watt/Second AS Battery 7024954),
and it only uses the expensive EH Pro Mini heads. For use in studio I would have to buy a AC converter-something not to wear out the battery; also expensive.
Still haven't totally discarded this one, but a lot of minuses...
After more research I landed on this one:
Elinchrom Digital style 600RX
+ Flash speed
+ Powerful
+ Skyport
+ Six f-stops
- Not 230V AC? I live in Europe; if this only comes with 120V, this is a no-deal for me :(
- plastic build
- only 7mm umbrella hole
Loved the Skyport, f-stop range and flash speed. Think I might would have chosen this, but then I saw the power output: 110V. Damn! Don't they exist in 230V?
Did a looot more research and was thrilled to see that Profoto's D1 wasn't too expensive and looked to be outstanding.
I had aaalmost made up my mind...
Profoto D1 Air 500/500
+ Profoto :)
+ 300W modelling lamp
+ Air System Radio W/ remote
+ Power adjustment knob
+ Totally wireless: built-in radio recievers
+ Seems solid
++ Can be hooked up to the Profoto BatPac (Profoto BatPac Portable Power Source (Multi-Voltage) 901124 B&H)
which isn't horrifyingly expensive, which means that I can use the D1's on location without having to buy new heads as well. Genius!
- The reflector is built into the monolight itself (!) and doesn't have a wide enough angle to give a good result with big softboxes. Idiots!
- Read that using it with a Profoto beauty dish was almost impossible bacause it was to tight a fit.
- On my cash limits; I would have to invest in a third monolight, the 1000W is expensive.
Everything seemed so perfect! The integrated reflector is the biggest problem! Does the zoom fix that? I think not...
Now I feel that I'm back at square one... or zero.
Surely someone out there have a monolight kit which they are totally happy with.
Someone who can either trivialize the problems and tell me the solution to some of all these minuses
or
can magically show me a kit which is all good!
Perhaps you can tell me that monolight kits aren't the thing for me after all, but
PLEASE: Help me buy the right kit/brand.
Maybe someone would even like to post a link to their pictures taken with a certain kit, so that I know what is possible.
If I have to add another $1000 to get what I need; so be it!
THANKS <3
The Style RX lights can be hooked up to Alien Bee Vagabonds and Innovatronix Tronix batteries (my favorite in the prive range). I believe they make a 120 and a 230.
Have you looked at bowens ? lots of cheaper modifiers, nothing wrong with your choices but modifiers can get a bit pricey for Elicrom but they have a very short flash duration great for action shots and very reliable
Elinchrom:
But what about the 110V issue?
And the umbrella hole?
What portable solution is there for the RX?
I thought you purchased the Hensel's??? I am surprised by your questions regarding Elinchrom's with so much information available on the Elinchrom website.
Elinchrom:
Why do you have 110v in Norway, we have 240v in UK, i only buy construction tools from US because on building sites we have 110v
It's the oposite; we have 230V in Norway.
It looks like B&H only sells 120V:
Elinchrom Digital Style Combo 600RX Two Monolight EL 20728.2 B&H
GeorgieGirl:
I did, but called and put it on hold.
Really cannot make up my mind; feel that I will have some sort of problem no matter what I choose.
Can't believe how you find it so easy to choose.
I play cards. No matter what, at some point you have to just have to pull the trigger based on what you know and what your gut tells you. You will have made an educated decision with the best information avaialble to you and you take your chances knowing that no matter what you will make the best of the outcome and enjoy the experience. With what you are looking at, Hensel, Elinchrom, Profoto there is no 'wrong' choice. Pick what feels right to you.
In the end, I picked Elinchrom because the light housings were translucent purple at the time and I bought my house because it had a fireplace.
I will always vote Profoto. Their lights are just an absolute joy to use. I think they're nearly perfect. Solidly built. Fast recycling. Accurate color temp. Billions of useful modifiers (and a very flexible/durable modifier system). The only downside is price. I still think some Broncolor lights have Profoto beat, but you pay through the nose and they're almost clinical, if that makes sense.
Not sure if alienbees go both ways on voltage BUT look into them
2 ab800 with stands umbrellas are around 1000 usd. Add two mini vagabonds for portability that's about 1600 usd.
Good luck
Elinchrom:
My post, read it.
Good luck
Profoto, Elinchrom, Hensel, Alien Bees.
Which one doesn't belong. Besides, try getting those overseas and also see how much fun AB's great customer service is when you have to do international shipping.
GeorgieGirl:
Then don't buy from the US and you won't get 110volt
Elinchrom does make the lights in 230V in case its thought they don't.
