dolina
- Joined
- Oct 6, 2010
- Messages
- 544
- Reaction score
- 411
- Location
- Islas Filipinas
- Can others edit my Photos
- Photos OK to edit
I'd look at the other photos... namely those of peopleAs I laways do I look at images on flicker after searching under the naem of the camera.
This one seems underwhelming…..
image removed by moderator
This one is very good, but could have been taken with many cameras.
I have seen some night shots of various cities taken with other cameras I suspect woudl be better taken with this camera, however, none of htose have been posted.
ANyone have soething that shows off it’s talent?
Just a heads up, unless you own the copyright on an image you are not allowed to post an image on TPF. Instead you need to post a link that refers back to the image.As I laways do I look at images on flicker after searching under the naem of the camera.
For the purpose of clarification... Even when the owner of the image allows for Flickr to create bulletin board code to hotlink to their images?Just a heads up, unless you own the copyright on an image you are not allowed to post an image on TPF. Instead you need to post a link that refers back to the image.
Man, ask the refs directly. Still, if you didn't make it, don't post it. Seems clear enough. Besides, this is bigly OT. Remember the GFX 100RF???For the purpose of clarification... Even when the owner of the image allows for Flickr to create bulletin board code to hotlink to their images?
I'm the thread starter... ;-)Man, ask the refs directly. Still, if you didn't make it, don't post it. Seems clear enough. Besides, this is bigly OT. Remember the GFX 100RF???
I'm thinking this way...I did look at the people images… but nothing that stood out for me. I anything the maxim “If you arent already taking good images, buying a better camera won’t help.” comes to mind. Taking ho hum images with a great camera is a diservice to the camera.
Buy a Mac Mini and you ca put a 27”to 32” screen on it and get an M4 chip. YOu won’t believe the speed. My old 27” iMac worked until I took it to the dump. But in warm weather it overheated., and the monitor shut down. Then I was stuck. The MacMini lets me use whatever screen I want.
